Doors opening on to stairs
Quickstep | Posted in General Discussion on November 20, 2003 04:21am
I am building a screen porch that will be off of a small foyer. (see attached drawing) The screen porch is 16″ lower than the room that it’s accessed from. Because of the layout of the rooms, I want the french doors to open into the screen porch; onto the stairs. When the room is in use, the doors will always be open, but as it stands, I know it probably won’t pass inspection. I hope to remedy this by making a platform at the same level as the room and sufficiently wide that it give a person a place to “land” as they open the doors. The question is this: How wide does this need to be? Is there a code guideline?
  1. DougU | Nov 20, 2003 05:21am | #1
    ChuckT
    I have seen codes that say you have to have a platform of 36" X 36", I'm sure they vary but you should check with your local building dept. That's the only one that's going to matter.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
