Downsizing from 1.5 to .75″ h2o meter?
Karl | Posted in General Discussion on October 26, 2008 09:25am
Hi all,
I am hoping some of you can help point out any problems I may be overlooking in my latest brainstorm.
I am trustee of a piece of family property and am trying to get the utility costs under control.
82 dollars of the monthly water bill is a “ready to serve charge” for the 1.5″ water meter. If I ask them to downsize to a 3/4″ meter the ready to serve charge is approx 20 dollars/month so I would save $700/yr without doing anything to reduce water consumption.
The property is 6 acres, once used for agriculture or livestock but not in the last fifty years. It currently has a large victorian era house, an 800 sq ft guest cottage, a 600 sq ft guest cottage and a 400 sq ft guest cottage.
There is a year round creek on the property that supplies all the irrigation water for non potable applications.
The water consumption ranges from 5 to 10 “units” per month with each unit being 748 gallons so the property currently consumes between 4000 and 7500 gallons/month.
The water main for the property is approximately 1000 feet of 2″ pvc pipe and each building tees off this with a 3/4″ line. The water pressure with no flow is 95psi.
I just ran across a 500 gallon pressure tank for 250 dollars and it got me thinking about plumbing that into the water line and downsizing to a 3/4″ meter. Even though the smaller meter is only rated for 30 gallons/min and the 1.5″ meter is rated for 100gal/min I am thinking that the 500 gallon pressure tank would keep sudden demands for large volumes of water from having a huge effect on the water pressure. The largest demands I can imagine are filling the washing machine, taking a bath or showering. Anything that would really take a lot of water (irrigation, etc) would use the creek water.
The city will swap out the meter at no charge and let me go back to the 1.5″ meter, also at no charge, if I change my mind in the 24 months following the meter downsizing. After that there are apparently huge “development fees” should I ever want the larger meter back. The water dept employee wasn’t especially precise but said the fees can run tens of thousands of dollars.
I can’t see wanting the larger meter if the pressure tank works effectively to cushion any sudden drops in pressure. If I recall correctly the 3/4″ meter is considered appropriate for up to 35 units/month of the 748 gallon “units of measure” the water dept uses so I could triple the maximum consumption ever billed before the statistics started indicating need for a larger meter.
The political climate makes developing this property almost impossible so it is unlikely it would be anything other than a single family ranch/estate with potential for a few rental units.
Until some taxes returns are prepared it isn’t clear if the property will need to be sold but the ultimate goal is to keep it in some sort of family ownership for at least the next generation. If it looked like the property needed to be sold I should know in the next year or so and if a larger meter really made a difference in the sale price of the property I could request the city reinstall the larger meter at no charge.
The only other glitch I can see is needing a mechanism to ensure that my pressure reservoir couldn’t backflow into the city’s water mains in the event they depressurize their system. I would assume a backflow prevention device could do this fairly effectively.
So if the water needs can be adequately met with a 3/4″ meter and a pressure reservoir, I am hoping to save $700/yr by spending $250 on a pressure tank, an unknown amount for a backflow prevention device and an afternoon doing some simple plumbing connections.
What do you all think? Is it worth it?
Thanks,
Karl
  1. Karl | Oct 26, 2008 09:34am | #1
    I neglected to mention that I am aware that a 500 gallon pressure tank does not offer any where near that much in the way of drawdown capacity.
    In a typical installation with a pressure pump cutting in and out to keep the tank charged it would have 36 gallons of draw down with the switch set at 40psi cut in 60psi cut out.
    I don't know how relevant that 36 gallon figure is in my application as the water supply is constantly trying to repressurize the tank without any delay waiting for the pressure to drop to a pump cut in point and the relatively high 95 psi line pressure may have some impact as well.
    Karl
  2. ponytl | Oct 26, 2008 12:46pm | #2
    if they will switch it out for no cost then i'd go for it...  i had a commercial property that had a 3" waterline/meter  there was no demand charge or no upcharge... it was a former carwash..  now retail... only 2 restrooms... the bill ran about $15mo...  but the water co figured i was use'n more but that the meter couldn't read that small of a flow.. so they spent 3 days and  3 trucks  and like 12 guys dig'n up the street and sidewalk to put in a smaller meter...  had to cost them 15k to do it...    now my bill is....  $15 a month....   i do have a building that had a gas meter but we used no gas... but it was $20mo just to have it... i kept it there just in case... then without notice they went up to $100mo to have it there... took me 2 months to figure out what was up... before i told them to remove it... they would not refund my $200... so i guess they will be ahead for the next 8 months... but i'd been pay'n the 20mo for 5 years...  meter guy told me they had removed 100s of meters like that... stupid... but who knows...
    p
    1. Karl | Oct 26, 2008 07:31pm | #3
      Thanks for the input. As far as I can tell I can't lose much more than a day of my life and possibly some water pressure. Five or six months of savings should cover most of my material cost . If I don't like the results I can always switch back.The size of the actual pressure/volume reservoir created by the tank is still a big unknown to me in an application like this.I am going to buy the tank in a few hours.
      Karl
      1. Piffin | Oct 26, 2008 09:42pm | #4
        There is some chance that you would suffer flow and pressure loss with so many living units, it all use water at the same time, say showering after a sweaty tennis match before dinner..but I'd take the chance, especially given the grace period on change back for free too.BUt give your self some time on that end. I can see them finding administrative ways to 'delay' making the change back until after the deadline so they can soak you - no pun intended.
        1. Karl | Oct 26, 2008 10:36pm | #5
          Piffin, Good point about not waiting til the 23d month before changing back if I find it necessary. The big question at this point is how much buffer against pressure loss the 500 gal tank will give me with a steady supply at 95 psi.I just got back from buying the tank so it looks like I am going for it.Karl
