Drain for condensation line
Cooper | Posted in Construction Techniques on November 24, 2006 07:19am
I’m currently building a mastersuite addition that features a newly installed miniature furnace/AC in the existing attic to heat/cool the new space.  Part of the installation requires a condensation line drain.  My question is: Can I tie that line into the plumbing vent system (wet vent).  Or do I just run it out the house under an eave?  If I were to tie it into the vent system, would I just add a wye and miniature p-trap and branch off the main stack?  Any ideas?
Much appreciaton to all ideas!
  1. FastEddie | Nov 24, 2006 07:26pm | #1
    Don't forget an overflow pan and drain line.
  2. jimcco | Nov 25, 2006 05:35am | #2
    Be careful under the eaves. I was out walking the neighborhood yesterday, read wakling off TG Turkey, and saw a house with a broad rust stain spreading down the side of the house from a condensate drain. Don't know why it was rusty as condensate should be rust free ; but I was really ugly.
    1. DonCanDo | Nov 25, 2006 03:17pm | #3
      OK, but was the stain on the house ugly too?
  3. VAVince | Nov 25, 2006 03:32pm | #4
    Will you have gutters? Put the drain into the gutter.
  4. Shacko | Nov 25, 2006 05:51pm | #5
    Most codes that I work with will not allow a solid connection to the santary/vent system, it must be connected to a storm water line or run to grade outside the building. Make sure that you read the manufactors instructions, some require a trap regardless of where you run the line. Two things pertain to this post, manufactor and local code. Lots of luck.
    "If all else fails, read the directions"
    1. ThumbBanger | Nov 25, 2006 07:01pm | #6
      Don't know where you're located, but a drain to the outside can freeze, backing condensate up into the furnace and shutting it down.  I had to pull mine inside, install a pump, and run it into a trap attached to a sink drain line.
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
