This may sound like a stupid question, but here goes……. If I am using dry wall anchors to mount a shelf to a wall and the anchors are rated for 50 lbs, do I get 50 lbs of weigh capacity for EACH dry wall anchor (ex. three anchors providing 150 l. weight bearing capacity) or is it only safe to use a TOTAL of 50 lbs for the total weight bearing capacity? Any thoughts on the preferable dry wall anchor?
Thanks as always for taking the time to read this.
This may sound like a stupid question, but here goes....... If I am using dry wall anchors to mount a shelf to a wall and the anchors are rated for 50 lbs, do I get 50 lbs of weigh capacity for EACH dry wall anchor (ex. three anchors providing 150 l. weight bearing capacity) or is it only safe to use a TOTAL of 50 lbs for the total weight bearing capacity? Any thoughts on the preferable dry wall anchor?
