Drywall mud. What’s other compunds are available that dry quicker andallow mutiple coats to be applied during the same day. Thanks
Setting-type joint compound. Usually labeled as 45 or 90 minute stuff in HD and Lowes. Contains plaster. Shorter times are available.
Setting-type compound sets up quicker, but it's not so easy to sand. Some use Durabond (setting type) for the first coat, and finish with regular compound that is easy to sand.
Or, find a skim-coat plasterer and have the whole thing done in a day with a much better product.
Al Mollitor, Sharon MA
Paul,
I like USG Easy Sand.
http://www.usg.com/IC/products/compound/easysand.asp
KK
plaster
Buck Construction
Artistry in Carpentry
Pgh, PA
