Drywall newbie- need some advice
| Posted in General Discussion on December 10, 2001 07:18am
Hi-
Plunged head first into my own small basement remodel and need some advice on taping sheetrock. I have done some taping and mudding (mainly with fiberglass tape), with very good results, and am planning to use rounded steel corners on some areas in the basement over door openings and the like. I also would like to use steel inside corners at the ceilings, and my question concerns the type of corners I have. Both of these corners are steel with a paper tape stuck to each side of the corner piece. What is the best way to hold these corners in place on the wall when I begin mudding? Staples???
Thanks for the advice…
  1. dave_c | Dec 06, 2001 06:07pm | #1
    Mud up your corners with Joint compound to hold it in place, then squeeze it out with a 5" or 6" taping knife
    1. Justus1199 | Dec 08, 2001 05:57am | #2
      *I always use white vinyl corner bead, and I staple it in place. paper always seems to blister and pop over doors and windows. the nice thing about the white vinyl besides the fact that it's self supporting is that paint stick to it better than metal corner bead and if you do ding the corner, it's white anyway.
      1. Tim_Kline | Dec 08, 2001 08:37am | #3
        *Rounded steel corners ? Steel inside corners ? Are you talking about bullnose corners ? (a corner with about a 1" radius ) Why would you want a steel reinforced inside corner ?
        1. Justus1199 | Dec 09, 2001 04:50am | #4
          *I think he was talking about the paper tape with two metal strips in the center, I don't bother with it, paper tape in the corner seams hold up pretty well as long as the house isn't moving.
          1. BrianGale | Dec 10, 2001 07:18pm | #5
            *Thanks for the info- the rounded steel outside corner I refer to is the bullnose, the thought on the steel inside corner is that it makes a very straight corner at the ceiling, which I have found that it does.-B
  2. BrianGale | Dec 10, 2001 07:18pm | #6
    Hi-
    Thanks for the advice...
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
