Hello, I recently purchased my first home and I am working on changing out some wood wall studs and a few ceiling joists. I have noticed that after putting up some studs, although they are leveled, when I put up a straight edge against them, there is some bulges on some and they maybe about 1/16 gap between straight edge and stud. This is frustrating, since I am a perfectionist. I purchased a planer, and got it down pretty darn well, but its not perfect. I plan on installing 5/8 drywall on walls and ceiling. Can someone elaborate on how perfect it must be ??? One guy told me that the drywall makes it perfect. Other websites state up to 1/8 gap between drywall and stud is okay. Please let me know.
This is why god made shims.
To get the ceiling perfect, hang furring at right angles to the joists, use shims and a laser level, and buy drywall long enough to span the room without joints.
do not try to put the drywall edge along a 2x4 run wall panels horizontal.
Unless you are going to put mirrors up, you will not notice the fraction of an inch once it is painted, unless you have a direct sight line along the wall.
Studs are wood, wood has movement even sometimes afters years in service. !/16" is not practical as a concern. Being a perfectionist is your burden but sometimes it's more sensible to try to accept the fact it can't happen at the level you hope for.
