Can anyone give me the pros and cons of drywalling a cathedral ceiling before installing wood panelling? I want to put 1×3 tongue and groove pine panelling on 2×8 rafters (16 in. centers) with R30 batt insulation between them. Someone suggested drywall under the panelling would be a good idea — for insulation? as a cold/hot air barrier? fire retardant? How important is it to drywall under the panelling? I live in northern Ohio and winters can be fairly severe and summers rather hot. I’d appreciate any advice anyone has. Phil.K
Learn about balloon-framing construction techniques, including stud patterns and efficient assembly methods with minimal manpower and scaffolding.
It's late, and my mind is old and feeble tonight, but I don't think you can fit FG batts R-30 into a 7" rafter space and you still need to allow for ventilation.
That aside, I have done plenty of t&g directly over rafters. As long as there is a VB
You are correct r30 is 91/2 inches think. Unless you use something like Owens Corning r30c which is 81/2 inches so it can be used in 2x10 rafters. It would be a waste of money to put it in.
Compressing insulation takes away some of its r factor.
You also need to have room for ventilation as well.
Thanks for the innoculation against that attack of CRS disease.
Your local AHJ might require for fire barrier, depending...only they can say.
