I’m sorry if the answer to my post is obvious, but I’m completely stumped…
I have two staircases above each other in my house, both with a winder box. I’m trying to drywall the back of the staircase to finish the hallway leading to the basement, but I can’t get the drywall to follow the arc created by the winder box. I’ve tried a couple of techniques including using wedge shaped pieces to create the arc and wetting the drywall to make it more flexible. I’ve thought about using metal lathe, but I haven’t gone to that extreme yet….
What is the right way to drywall the back of set of winder stairs?
Thanks!
Oliver,
First off, welcome to Breaktime. Please fill in your profile as soon as you get a chance.
On to your question: Can I ask what thickness your drwall is? I would certainly use 1/4" material because it will allow you to twist and conform to shapes a bit easier.
Justin Fink - FHB Editorial
Standard 1/2" at this time. I've learned now that it doesn't bend.... One thing I haven't seen in my local home center is 1/4". Is it readily available?
Thanks.
It's a bit less common in the big box stores, but you should be able to scare some up from a drywall supply house. Or maybe a building supplier?
comes in the standard 8 ft. lengths, and also in 10 ft. lengths as well.
If you really can't find 1/4"...you could try 3/8" - but that probably won't give you much more flexibility than you would find in the 1/2" you've got now.Justin Fink - FHB Editorial
HEY!!!
That is The Razzman's JOB! ( fill in your profile....dada da da daa da)
Has Taunton out sourced his only means of free subscriptions?
Shame on you! I'm tellin.
( all in fun, there, J ..all in fun)
GIVE RAZZ HIS JOB BACK! Spheramid Enterprises Architectural Woodworks
Time, time, time look what's become of us..Time is all we have, spend it wisely with fervor..dance for no reason, love with out plans and live without worries..we all can.
heh heh Sphere!
You villain!
A person with no sense of humor about themselves is fullashid
See if this helps... http://www.carpenters.org/carpentermag/0203/TrdTlk34_03.pdf
Wire lathe & Structolite for scratch.I Love A Hand That Meets My Own,
[email protected]
I didn't know Martha Stewart was so up on drywall techniques and the Carpenter Mag.
Will wonders ever cease?
Yep, 1/4" should work. Lay it over something curved and bring out a mop and a bucket. Wet it down again and again.
Welcome, to the board. The profile is nice so we can where you are located.
Go to a good lumber yard and get 'wiggle board"..it's plywood that bends. Then go to a drywall supply house and get 1/4" High Flex Drywall..this is not regular 1/4"..it's made to bend to a radius of 1 1/2 feet without watering. Then hire a drywall pro...I' mean a pro.
The other solution with structolite also works fine..just takes longer.
A couple of posts recommend 1/4" plywood - try 2 thicknesses, tho, with the outer being birch or similar that'll take mudding and finish out like D/W does. Especially if you cqn't get specialty stuff.
Ciao for niao
***I'm a contractor - but I'm trying to go straight!***
