I had wired the bathroom switch with 14-2. This was fine as long as I used the mechanical switch, but I would like to change that to a electrical timer switch. But I don’t have a neutral line.
Wiring sequence is this: 1st junction box (basement) has a split that makes the 14-3 into 2 circuits. One circuit goes to 2nd box (bathroom wall) that holds the light fixture. Wires for the switch (14-2) goes out of the 2nd box.
I want to bypass the 2nd box. I want to put a single neutral wire between the switch box and the 1st junction box. I will use bx for extra protection, leaving only the neutral, and labeling it for the purpose.
Can I do this?
Not legally.
All conductors in a circuit must be grouped together in a cable or raceway.
I would suggest buying a timer that doesn't need a neutral and gets power through the load.
If you can fish from JB#1 into the box with the switch, pull in a 14-2, hit the switch/timer, use the wire from the switch to the light going the other direction and abandon the wire going from the light to the JB#1.
Remove any reidentification tape you mayy have used on the switch leg since the white is now a neutral again.
Thank you both for the answers. I was proposing to use the bx to show that lone neutral is protected, but I was half expecting to hear that it is illegal.
Pool installation
I actually have a problem with my pool installation cost
My pool guy charged me so much I just dont even want to think about the electritian. Can you help?
http://pool-contractors-la.com/pool-installation-cost.html installed a pool system and it electrocuted my grandmother.
boy
That princess bioche is one screwed up mama.
Look at the profile, typing for effect is certainly her forte'.
Access denied.
denied?
that's a kick in the pants.
