Some electrical circuits in my older home (built in 1974) have me concerned due to my limited knowledge in the electrical area. I have a double 20 amp breaker in my panel that uses a 10-3 cable to a junction box where it breaks into two 12-2 circuits. One of the 12-2 circuits then breaks into one 12-2 line and a second 14-2 line. Can I safely have a circuit that goes from double amp 20 with 10-3 cable to 12-2 cables to a 14-2 cable?
Ford Motor Company slashes prices for some F-150 Lightning models to stimulate demand for electric vehicles (EVs).
Everything you described is normal for a shared-neutral circuit, up to the 14-2 part. In my jurisdiction you cannot protect a #14 wire with a 20A breaker. It sounds like it may have been added after-the-fact by a previous owner.
The first wire does not need to be 10-3 -- 12-3 would have been adequate. However, the 10-3 is not a problem or a code violation.
You can split as many 12-2 lines off the original circuit as you want -- nothing in code to prevent it (with a few obscure exceptions) and nothing hazardous in doing so (within reason).
The 14-2 line should not (by code) be connected to a 20A circuit. #14 romex is limited to 15A in current code.
This is not even a "current
This is not even a "current code" situation. 14ga wire has been required to be protected with 15a breakers since the Hoover administration. You might be able to find a 2 pole 15/20a breaker but it would be easier to just put in a single 15 and a 20 with a listed handle tie.
Another legal solution
Gfretwell said >>... it would be easier to just put in a single 15 and a 20 with a listed handle tie.<< This is a practical, safe, legal solution.
Another solution would be to change the run of 14/2 to 12/2, if the existing 14/2 is accesible this may be a simpler / cheaper way to go.
Which way you go depends upon accessibility of the 14/2 cable run(s?), and whether you can tolerate the reduction in amp rating for the rest of the circuit leg which has the 14/2 cable present in it.
The 10/3 section of cable is not a problem either way - being "down-rated" merely serves to reduce voltage drop in your 20A circuits at the point of use.
By chance is the 10/3 cable to your first junction box a relatively long cable run? If so, it was probably installed "on purpose" to reduce voltage drop.
Jim
Another thing bothers me here. You said 10-3? Is that aluminum? They were still using it in 1974. That will rip open a whole new can of worms.
Al worms?
>>....Is that aluminum?......... That will rip open a whole new can of worms.<<
Hadn't considered the Al possibility for that 10/3......
If Al wire then the 20A breaker is sized correctly for the 10/3 and 12/2 copper; the 14/2 run of cable is still a problem.
Not that large a worm can even if the 10/3 is Al. 1st j-box gets 4 listed Al-to-Cu wire nuts, panel wire ends get some Al anti-oxidizer and you are done with the Al wire issue. 14/2 still is problematic with 20A breaker - never seen any 14/2 Al cable.
The purple, Ideal, Al-to-Cu wire nuts are pricey at ~ $2.40 each at a big box. but they solve the problem quickly. They have about the same wire capacity as a red wire nut. $10. worth and you are done. Sometime available as a 2 pack for ~$ 5.
These:
Twister Al/Cu (Card of 10)
Catalog # 30-765
Features
Aluminum-to-Copper connector provides a secure connection while preventing aluminum corrosion
Specially formulated corrosion-resistant compound provides cooler connections and increased conductivity
Accepts 1 #12 Al sol. w/ 1 #18 Cu AWG min. and 1 #10
Don't know why my cut and paste came out this way - last line should read ".......#18 Cu AWG min. and 1 #10 Al solid w/1 or 2 #10 Cu solid max." Therefore, 1 #10 Al solid w/ 2 #12 Cu solid is within their approved range.
Jim
There are also some good CU-AL insulation-piercing connectors. I forget the name, but I keep a few in my kit of random stuff.
