I am interested in finding out peoples thoughts on the most appropriate wood(s) to use for an end grain wood floor I am starting. I will be using butt ends 4×4″ (?) sections aprox 3″ long. glued onto 3/4″ subfloor. Also any hints on if there are inexpensive sources for this material or does one ‘bite the bullet’ and simply buy necessary stock in full length lumber?
Thank you much – new member to this fine forum.
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
I will be undertaking that myself this winter. I am using red and white oak and cherry in 4x4 and 4x6 , I want a pattern.
I am intending to use Bostics best trowelled down With 3/16th notches. I am leaving a grout space about 3/16th. My blocks will be 1.5" thick ( I already had to raise some stuff, like doors to accomodate that), with a sawdust and POLY/Linseed oil binder.
I calculated how many block I can get out of a "rail" of 4x6 from my local sawmill, and add about 20% for for extreme checking or defects. My whole floor will come in around a buck a sq.ft Plus labor. I bought the 12" Bosch saw just for chopping all the blocks.
I also intend to create a slight champher on all the top edges, a routertable is the best way, or a stationary belt sander.
Every year or two I will reoil the floor, thats all.
Now THAT is an ambitious project!!
Hold on to your fingers.
Why so thick?
EricIt's Never Too Late To Become
What You Might Have Been
[email protected]
Why 1.5" thick?.. Well, I have a transition from the LOG part to the NEW part right there in the kitchen..it now is about 4" and an awkward step. I figgured I'd make it more like a Step, than a toe tripper.
Also the wood I will be using is AD and WILL check shortly after sawing...so a bit thicker is mo betta IMO.
When I added the outside door I left a PT bottom plate, and also figgured the counter heights and such for 1.5" added..so Now I am kinda commited..( or oughtta be..LOL).
I feel the champher is the finishing touch detail..more like a paver than a tile look..and the edges will be splintery if I don't do something, I expect the grout to shrink a bit, and this is all I could come up with. Spheramid Enterprises Architectural Woodworks
Hey Sphere, I'm curious about that 3/16" "grout" joint. Grew up in a 18th C house in PA. Walnut floors with a linseed/sawdust like gap filler. Musta been boiled linseed oil, cause it was hard. The boards shrank & expanded, but I don't think that the filler did. I'm sure you've got a reason, but why not just jam everything up jelly tight, with a perimeter gap?And, can't you get any Hickry outta Doud?<g> "what's in a name?" d'oh!
Good point on the grouting..VS tite as a frogs azz. The BOSS wants the LOOK of the grout..See, anything to keep me working at it forever makes her happy..LOL
I can get Hickory here and may include some..depends on the mills attitude and what they are sawing at the time. I can't afford to buy from David with gas being so high..and then this.
I JUST got my van back today, after 4!!!! FOUR days of tracking down a stinking 11 dollar heater hose. Halfway to Frankfort today ( to add my contribution to the "Goose Chase").... and they called me back and said, " uh, were just gonna MAKE a hose" Arrgh..
So That, vehicle is NOT traveling very far from home much more..when it blew FRI afternoon, it was 78.00 for the tow. Spheramid Enterprises Architectural Woodworks
Ahhh, a nudder version of being "hosed" <G> Arrrgh!Sounds like a sweet floor. I'm thinking of something like it in a half bath...a whole bunch cheaper that $6/4x4 tile my boss has been 'snortin around. LOL "what's in a name?" d'oh!
