>Does anyone know if the use of “glue lams” is recommended for marine construction? For example, I need to replace two 25′ beams on a boat house ramp that is partially submerged in salt water. I was wondering if I could use “glue lams” for this application vs. solid wood beams?
>Does anyone know if the use of "glue lams" is recommended for marine construction? For example, I need to replace two 25' beams on a boat house ramp that is partially submerged in salt water. I was wondering if I could use "glue lams" for this application vs. solid wood beams?
