Enough CB Amps for Electric Heater?
I live in an appartment with 4 Electric Convection Heaters. 1500W, 1250W, 1000W & 500W all at 240 volts. The 500W heater in my bathroom needs to be replaced to a 1000W/2000W Forced Fan Heater. Can I install this type of heater with a Double 30amps Circuit Breaker (60amps in total) which handles all my 240 Volt, 4 heaters in my appartment? Will these breakers handle the load? What is the Maximum load I can use with these breakers?
Your answers will be appreciated.
Greg
Note - that 220 v 30 amp breaker is just that - 30 amps.
W=AxV. At nominal 220V
1500W=7.5A
1250W=6.25A
1000W=5A
The new heater looks like it would be 2000A at 220v =10A
So the 3 existing heaters with the replacement would be 28.75A, which is too large (I believe) for a 30A service - IIR, 25A is the most that should be run off that breaker
"Ask not what the world needs. Ask what makes you come alive... then go do it. Because what the world needs is people who have come alive."
Howard Thurman
Hello RJW,
Thanks for your info. I have a question. See my photo attatchment. On my breaker it seems to be a double one. Is it 30A+30A=60A? or it's still rated at 30A for 220V?
still rated at 30A
Howard Thurman
Thank You
