Entry Gate Hardware
joewood | Posted in General Discussion on July 8, 2004 07:33am
Anyone have a source for some quality gate hardware, especially the locksets/latches?
I’d like to find a solid brass entry lockset, but all the ones I’ve seen don’t work on a style thicker than 1 3/4. How about some other type of high-quality latch, that you can lock and unlock from either side?
  1. Jamie_Buxton | Jul 08, 2004 08:22pm | #1
    If you drive a Mercedes-Benz, check out Rocky Mountain (http://www.rockymountainhardware.com/).  Fine stuff, but not inexpensive.
    Edited 7/8/2004 1:23 pm ET by JAMIE_BUXTON
    1. HealeyBN7 | Jul 08, 2004 08:47pm | #2
      For example - the farmhouse sink is $13,203.10  but available in any finish...
    2. gdavis62 | Jul 08, 2004 09:21pm | #3
      Full mortise entry handlesets can be had from a good Baldwin dealer for $500 or less.  The Rocky Mountain stuff is at least twice that, maybe three times.
      What a premium to pay for that heavy rustic look!
  2. Piffin | Jul 09, 2004 12:17am | #4
    I'm confused by your wording whether you want Gate hardware or house door entry locksets.
    Acorn has several types of Gate hardware and entrysets both.
    Rocky Mtn, Bladwin, andf Emtex all have good entry sets
  3. woodguy99 | Jul 09, 2004 02:28am | #5
    http://gatelatchusa.com/s-cart/Index.phtml
  4. tyke | Jul 09, 2004 03:16am | #6
    Try vandykes.com. they have all older looking hardware and accessories all shapes sizes and thicknesses.
    They are pretty good about delivery and on time.
    tyke
    just another day in paradise
  5. AdamB | Jul 09, 2004 03:16am | #7
    http://www.leevalley.com/home/main.asp
    1. tyke | Jul 09, 2004 04:27am | #8
      Yea I forgot about lee valley.
      tyke
      1. joewood | Jul 09, 2004 06:22am | #9
        Those are a few good links there, especially the Rocky Mountain one. Expensive, but I do need some quality stuff.
        Sorry if I wasn't too clear Piffin. I need this for exterior gates, but, I'd like to get door-style hardware, at least something that can be locked from either side, like an entry set. Problem I'm finding is that entry lock sets can't be installed on a style thicker that 1 3/4.
        I think next  I should start talking to the companies that make locksets.
        Hey, thanks for those links. Maybe someone else will come along with just what I need.
        1. Jamie_Buxton | Jul 09, 2004 07:20am | #10
          Joe --
            One caution about using entry sets on a gate...   Gates stand out in the weather.  Often they warp and change dimensions with the seasons.  Often they hang on posts which have no wall framing to stop them from moving around, and often the posts are not well-secured in the ground.   All of this means that gates often fit sloppily, and the fit changes with the seasons.   Entry sets aren't designed to take up this much slop, and so may not work very well on gates.   The usual gate hardware, while it looks somewhat crude, has a lot of tolerance built into it.   So if you're going to use an entry set, build the gate and the wall it fits in very well.
          Edited 7/9/2004 12:21 am ET by JAMIE_BUXTON
