Epoxy for bug damage
Bkcbuilder64 | Posted in General Discussion on June 26, 2009 03:59am
  I’ve got a job to do on a rough side out redwood clapboard sided house. I’ve got a dozen woodpecker holes that I will plug with redwood plugs, but also some bug damage here and there that I would rather fill. The house is due to be restained(semi trans) so I want to fill instead of replace on the claps and corners for match. (not my idea but a homeowner insists deal…ie: no choice for me)
 What brand epoxy/filler would be best in this situation? I’m gonna need something that won’t sag quick…dries fast so I can do a few coats in a day…and that will be able to be stained over…..sounds darn near impossible….what do you have??…..Keith C
    Jeff_Clarke | Jun 26, 2009 04:26am | #1
    What I always recommend:
    http://advancedrepair.com/architectural_epoxy/architectural_epoxy.htm
    View ImageView ImageView Image
    Works best with a flat piece of plexiglas for mixing, plastic tools and don't use the helical mixing nozzle.
What’s Old Is New — An Exciting Announcement
  • Installing Wainscots
  • What’s Old Is New — An Exciting Announcement
  • Mid-Wall Install
  • Issue 326 - October 2024
    • Paint Behind Strike Plates
    • Conceal Cut Ends
    • Ladder Slip Solution
  • Issue 325 - August/September 2024
    • The Cali Valley Heads East
    • A Deep Dive Into Continuous Exterior Insulation
    • Secrets of Thermal Imaging
  • Issue 324 - July 2024
    • Barn Transformation
    • I-Beam to the Rescue
    • Save With a Smart Thermostat
