Need some help with etching glass. I have sandblasted glass before, but need to “mask” an area before sand blasting for a sign. What is the best material to mask an area with? Was going to try vinyl lettering if possible. Thanks.
David,
There is a special mask for sandblasting. It is a heavy rubber mask about .040" thick with a peel off backing. Most sign places should have it if they are doing any type of blasting. My wife gets it from a local sign shop but I think it might be available where they sell sand blasting suppies too.
Vinyl might work, but only if you are lightly "dusting" with the blaster, not doing a deep etch.
Hope this helps,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Edited 2/29/2004 2:56:04 PM ET by MrBill
There's also etching paste that does its job chemically. You can get it at many glass shops, particularly ones that sell stained glass or other craft supplies. It doesn't etch very deeply, but does make the glass opaque. Vinyl stick-on letters are a good mask.
Also, for smaller projects the peel and stick "etched" stuff works well. easy to use and trim, I've used it in cabinets and nobody has ever guessed. Not for everything, just another option.
Jake Gulick
[email protected]
CarriageHouse Design
Black Rock, CT
I have etched a ton of glass... mostly for fun but i did a 25' x 30' storefront for a bar once... and all i've ever used was cheap discount store shelf or contact paper... and an opage (sp) projector hand cut it all with an exacto knife.. have used the same method using sign material to hand cut signs... all turned out well... the grit of the sand does make a difference... but it's not rocket science
pony
I've sandblasted both glass and slate, and several layers of plain old hardware store masking tape were my tool of choice. I found that the thick rubbery self-adhesive masking stuff was great for dead flat surfaces like glass, but peeled away far more readily than masking tape did on any kind of a curved or otherwise irregular surface. Plus it's way cheaper. Amazing how you can blast away 1/4" of slate while three layers of masking tape are resistant to the blasting!
I'd stay away from the chemical etchants. Etchants for glass all contain hydrofluoric acid or fluorides and are highly toxic as well as insidiously corrosive to your body. Hydrofluoric acid causes little pain on contact, but can make its way through your skin and start eating your bones in an hour's time. Painful and totally unnecessary.
so that's how to dispose of those nasty unwanted bones I got all over the place..HMMMMMmmm
Wait till you find a buried tombstone in the side yard.
We'll see you HMMMMMmmm ing a little quieter then I'll bet.
got a metal detector..lookin for the ol outhouse site!! Gotta be some buried loot some where!..
Outta be a dump out back not to far away.
Sometimes careful digging will uncover a large flat something that protected the glass underneath.
First bottle will get an honorary place on the b&g's fireplace mantel.
When demoing an old house once I met a guy that studied old land records to look for old cisterns and such. Claimed he unearthed a lot of goodies in the process.
yeah, I got a chance to talk with one of the old timers nearby..wealth of knowledge about my house..it's the oldest one for quite a ways around me. He is tryin to find any old snapshots he may have..so I can see what it looked like..way back. That will be sooooo cool. I am still finding out stuff about it..(hiding place for slaves and such)..and found out some of the hand chisled rocks from the hearth may be worth some coin..but I am using them in the new hearth and front wall of the porch..
When I was in the environmental clean-up business, one of the hazardous waste disposal companies was known to be run by two Italian brothers of questionable virtue. The joke around the site was that each roll-off box for disposal came with a free pair of "cement shoes"...Hey- who's a-gonna look in the toxic waste dump?
