Or, pull out trash bin conversion round 2…..
My “new” cabs have Euro-hinges, the little plastic do-hickey covering the adj. screws says “Capri”
The hinges seem pretty standard, cup in the doors, sub-base & base on the cabs…..but, I can’t make out how the sub-bases are attached to the cab. carcass—no phillips screws, and they don’t have the “ears”. Pull off the base and you can see little slotted somethings that seem to hold the sub-base to the cab. I tried unscrewing one, but just started to bend the slot.
Anyone know what these puppies are????
bumping myself.......
No idea
Key hole slot maybe?
Life is Good
Nothing I've ever run across. It could be that the mfgr was so vile as to attach the bases via a screw through the side of the cab into the back of the base. (Would kinda make sense if the sides are fiberboard too cheap to hold a screw.)
Or could be a keyhole, as someone else suggested. Try "gently" driving one of the bases backwards, or up.
can you post a picture?
Looong time ago back in the 80's I worked in a cab shop that used a hinge that had a slot cut in the frame and then frame protion of the hinge kinda clamped itself to the frame via this slot. Did the smae to the doors in many cases but drilled the doors for the cup in just as many.
I seem to remember hinges like that as well.
Had a slot in the cab frame and the usual mortise for the round portion.
Seems IIRC that there was a locking screw in the door side leg of the hinge. Dang if I can recall a clear mental picture of it though.
Life is Good
bipitty-bumpity...I'll try and post a pic, but I don't have a macro lens, so not sure it would help much
Maybe post over @ Knots.....
