Can I take the rails and move them over one direction to give my self more capacity on one side over the other?
I’m just sayin’
I've got a small Dewalt that you can do that on. But it's the only table saw I've used that that is possible on and it has pretty limited capacity. So I'm guessing the answer to that question is saw specific.
i was planning on drilling new holes, just is it ok do do that without screwing anything up
I'm just sayin'
Watch the CG, if you get it too far off center it will want to tip.
You might think about a leg of some sort under the table ends.
If it tips over it'll be nasty.
Joe H
yeah I was planning on putting an extra support.
I'm just sayin'
What brand saw?
Grant is guessing right, it depends on what saw. The older Craftsman had tube rails that bolted to the table thru holes in the tubes. Those could be scooched over, but sometimes you needed to drill and tap new holes in the table or wings.
I had an AMT that I modified by swapping a Cast Iron wing out for a wood router table top, and I had to move the fence guides to do that, I think it was just two new holes. Cast iron is real easy to drill and tap if you have to.
http://www.youtube.com/watch?v=Dj_oEx4-Mc4
Yes. I've done it. On an old tube style Craftsman saw. I think I did it on my 9" delta too.
Edited 10/22/2008 10:10 pm ET by popawheelie
cool, thanks
I'm just sayin'
