Can someone share with me what the benefit is for custom extension jambs for kolbe windows versus the standard jamb. What is the best construction method for attaching the custom jamb?
This is a new house with new windows.
Windows normally have standardized jamb depths based on 'typical' wall construction. Should you, for instance, furr or cross-strap a wall, use a double layer of drywall or a thickness of drywall inconsistent with the manufacturer's standard you would normally need to use extension jambs to bring the window jambs flush to the finished wall surface for the application of casing.
You can attach them with nails and glue - or better yet pocket screws if you have a Kreg jig.
Some have manufacturer-specific installation clips - like Kolbe - review this: http://www.kolbe-kolbe.com/files/installMaintain/instExJambApp.pdf
