Exterior French Door Installation
I will be installing 2 sets of french doors on monday.
The rough opening is plumb and everything I could ask for.
I would like to get some advice on the installation of this type of door. It`s been 2 years since I`ve done one.
Thank you
Exterior French
Who's the manufacturer? Most I've dealt with have a pretty decent instruction manual on "how to do it".
follow that for install and waterproofing recommendations. You should include some kind of pan under the threshold to deflect any water entry. You should also use flexible (peal and stick) flashing around the perimeter. I use only Urethane caulk to do the final prep b/4 painting as it sticks to everything and has great flexibility.
