I am building a 2 story addition, garage lower level with radiant floor heating, and master suite above. The foundation wall consists of 12″ CMU, stepped to 8″ for a brick ledge. The brick have been laid to create a knee wall about 18″ above grade. For the time being (and probably permanently) I’m going to side the wall areas above the brick. I haven’t decided whether to go with fiber cement or vinyl.
Question – should I install rigid insulation over the 7/16 OSB sheathing? If so what type? Would the choice of siding, vinyl or FC, affect the choice of insulation?
Exterior walls are 2×6 and I live in the PIttsburgh, PA area.
Jeff Buck, I believe you’re in this area?
Thank all of you in advance for your suggestions.
In cold country, the foam belongs on the inside of the wall
"The first rule is to keep an untroubled spirit. The second is to look things in the face and know them for what they are." --Marcus Aurelius
I can`t give you total advice, however consider TYVEK wrap home wrap by Dupont, for a good energy saving sub insulation...look the up on the net ...If you use http://www.google.com you can enter residential exterior insulation,and find several options you may not have yet considered... good luck..Mark Rogers G.c.#643905
