I Just installed a new single-hole lav faucet, but didn’t notice if the supply lines were marked for hot and cold.
One extends a little below the other. Is there some standard that the longer one is usually hot (or cold)?
I’d appreciate any help.
as you look at it hot is on the left
Single-hole faucet -- both lines come down the middle. Looked at my single-hole kitchen faucets and noted that the cold supply was longer, so I tried that on the new bathroom faucet and it worked there also.
Thanks for the reply. I'll be all set now as soon as I stop the leaks in the sink drain.
