Good day to all Im putting an estimate together for a length of 75’wood fence. Im putting together the material cost but am not sure of the labour charges I will be working with my 2 sons I will be digging holes for the post with cement around 4×4 post w/2×4 framing etc.Im estimating 3days work at 8hrs a day.
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
I can't offer suggestions on what you should charge but is there a lot of ledge in the area you will be working? You might want a clause to cover the case if you have to start pinning the posts.
Im assuming you mean setting the posts into the ground,well Im going into clay dirt so my only concern will be any buried solid refuse from years past so what I will do is drive a 3/4"x4' long metal spike into the area to be dug and if I do not strike anything solid then I wont lose any time for excavation. Cheers Pete.
I don't set into crete, I dig five feet deep. I figure dig and set one post per three manhours. Layout extra. Fence building extra. I have clay soil with large donuts - one every other hole
if the fence cost $500 in material charge $500 plus $500 per person Hell, I dont know, just making up numbers.
Edited 4/10/2006 9:18 pm by brownbagg
yeah, or you like digging holes cheap, LOL
"I dig five feet deep."assume you use power equipment?
bobl Volo, non valeo
Baloney detecter
$1,500.00 plus tax.
$1,000.00 plus tax for 50'
Grunge on.
Nope. hand pich diggers and a steel bar. Using a drill just hooks youi up on rocks and rooots andpulls the tail end of the tractor down into the eaarth with the front end end standing up
$99,500.17
If you have any poo, fling it now.
it's yurs... Mr low bidder...
beat me by 3 cents...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Thanks for your words of wisdom,I shall take note.
around here guys get about 20-25.00 a ft for 6' wood fence,materials and labor.i can't remember the grade of pickets. they are pretty good but has small knots.larry
Sounds like I should pay you about $3 per hour for you, and $2 each for the boys.
Sound about right?
Just kidding. Are you asking these guys to tell you what you should make?
Edited 4/11/2006 9:21 pm by intrepidcat
