Can anyone recommend a gap/crack/nail hole filler for mdf? Something I can apply and sand?
Thanks, Dennis
Thanks, Dennis
Bondo
Like Bondo, but a little finer texture. Spreads smooth and air bubble free. Body shop supply is where you'll find it.
http://www.crashsupply.com/cgi-bin/csupply/db592gr.html
PJ
Everything will be okay in the end. If it's not okay, it's not the end.
For small gaps (like inside miters), I use caulk. For nail holes, I use lightweight spackle.
body shop suppliers carry something referred to as glazing putty. It comes in a tube, is a one-part filler that dries quick, doesn't raise the grain, and doesn't shrink very much. It get's harder to sand the longer it dries however. I try to sand it within the hour.
mh ready patch.
dries very hard, sands, will hold up better than lightweight spackle, and paints well. --you'll find it at good contractor paint places, home depot, etc.
Bondo, but also like Dynapatch for skimming.
I have been using premixed joint compound, like drywallers use. works fantastic.
