FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Finding lines behind walls
Terrenord | Posted in Energy, Heating & Insulation on February 1, 2008 07:26am
I opened a wall while doing a reno and found a buried junction box.  So, I decided to do some investigating and found some hinky electrical work that roams around in the walls without any apparent reason.  I want to fix the problem, but I don’t want to rip all my walls out looking for wires that seem to have been run by a madman.  Is there a tool that detects wiring behind walls so I can chart out my service?
    JDRHI | Feb 01, 2008 08:09pm | #1
    I used to work with a guy that could find electrical wires in a wall with a nail or screw no matter how well they were buried/protected.
    He was pretty good at hitting, er finding, pipes as well.
    I couldgive him a call if you're interested. ; )
    Bump.
    J. D. Reynolds
    Home Improvements
    BillHartmann | Feb 01, 2008 08:22pm | #2
    There are, but I have not used enough of them to say that they will find them all.
    The proximity dectors ($10-20 pocket sized tick testers) will detect energized circuits for couple of inches. Sometiem they will see behind the wall, sometimes not.
    Some stud sensors have similar features in them. But, at least the basic ones, the range is limited and won't alwasy show them.
    You can get tone tracers for about $80-100 dollars. They are designed to help ID phone and cable wwires. They have a little more range, but they will only work on unergized circuits and without ANY LOAD. Have a light bulb on the circuit circuit that is turned on a wall wart plugged in and it won't work. And even when it works the range is not enough to always trace it in the wall.
    There are some more expensive units that work on energized circuits and can work with buried cables so I assume that they have the range. They run $350-750. I have not used one so I am not sure about the range and capabilities.
  3. cap | Feb 01, 2008 09:35pm | #3
    This Ideal Industries tracer is the best:
    http://www.idealindustries.com/products/test_measurement/circuit_tracers_analyzers/suretest_circuit_tracers.jsp
    It'll trace wires behind lath and plaster, sheetrock, 2-3 feet underground.  It'll positively identify a circuit breaker, even on a multiwire (shared neutral) circuit.  And it'll work on live or dead circuits.
    Of course, it's expensive.  If you're a contractor, it'd be worth it.  Hard to tell, you've got no info in your profile.
    Anyway, I don't own stock in Ideal.  They just make stuff that works.
    Cliff
  4. ans2 | Feb 05, 2008 12:40am | #4
    I can relate to that.  So far, I have found four hidden junction boxes in my kitchen.
    Greenlee has a circuit tracer,
    http://www.mygreenlee.com/Products/main.shtml?p_search=2007&greenlee_category_id=100&portalProcess_2=showGreenleeProductTemplate&upc_number=36924
    Power Finder™ Closed Circuit Tracer cat number 2007
    The regular retail price is around $400 US.  Greenlee has two other models with different capabilities.  I just picked up a used one on eBay for around $175 US including shipping.  I just did some preliminary testing in my kitchen to see how it works.  I have a partially open wall between my kitchen and family room.  (gyproc on one side and open on the other)  The device has "no" problems picking up the live electrical line through the gyproc at a distance of a couple feet.  I can then reduce the "gain" dial to more precisely locate the line.  The device also can tell the orientation of the wires.  For example, in my case, the wire are running parallel to the studs.  If I rotate the device 90 degrees, the signal detection is significantly reduced.
    The device seems to have no trouble detecting signals through 7/8 inch granite on the back splash in my kitchen.  Of coarse, I did not destroy the granite backsplash to confirm the live wires actually exist.
    Only time will tell whether the circuit tracer does everything that I had purchased it for.  Used Greenlee circuit tracers seem to be selling for (depending on the model) for the $200 to $300 US range on eBay.  So, I am hoping to recover most of my cost once I finish with my project.
    I am  sure that the Ideal Suretest tracer would work just as well (if not better).  Only problem for me was that the least expensive model at the local electrical supply store would have set me back around $1000 US.  Considerably more than I had wanted to spend.
Managing HVAC Load Calculations
It is imperative for someone at the end of an HVAC installation to commission the job to ensure the efficiency of the system.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • 2024 Tool Guide
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
