Fine cracks after re-painting T-111
user-6904244 | Posted in General Discussion on June 25, 2020 07:31pm
South-facing (hot in summer) exterior wall of my 2-story house has been painted several times.  I re-painted it myself in 2000 (over existing paint, with VERY thorough prep).  Then it was repainted with Benjie’s Aura several years ago.  Now,  a well regarded painting co. repainted it again.
It still has fine hairline cracks which the foreman tells me are not a problem, and will allow the wood to breathe.
They used peel-bond “primer” in spots, and then sprayed 2 coats (18 hr drying time in between them).
This is in the Pacific NW, so hot in the summer and wet all winter.
 Is this ok?  I can see that some of these cracks were not filled, and I wonder about them not back-rolling too.
Thanks.
    tfarwell | Jun 26, 2020 12:44am | #1
    I had a similar issue with cracking on my house - south side, T-1-11, house built in 1977, located in PDX. I ended up adding another layer of siding over it, as it was starting warp a bit between the studs. I decided it was too far gone due to the heat and water - and wasn't worth trying to paint.
    I put an air space between the old and the new, built out the trim etc. It was quite a bit of work, but 6 years later it looks like I just installed it.
  2. user-6904244 | Jun 29, 2020 01:54pm | #2
    My T1-11 is fine.
    My question is about these fine cracks that the paint didn't fill.
    Thx.
  3. SamiT | Jun 30, 2020 11:48am | #3
    May be due to the high humidity? Src - https://mypaintsprayer.com/painting-high-humidity/
