FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Fireproof roof for generator building
MikeR | Posted in General Discussion on March 27, 2005 05:09am
Hi folks,
I’m constructing a building for my aux. generator as I’ve previously discussed here.  I’ve laid up the CMU walls and am now at the point for the roof.  Am considering using some welded steel for the trussframe structure but not sure what to use as sheathing?  Reason being I want it fireproof.
I know they make flame retardant plywood but any other good options?  I thought of a metal roof but wouldn’t that require some means of sheathing underneath?  Span is not a big problem as the building dimensions are only 6′ x 6′.
As always, any thoughts or ideas are appreciated!
Mike
  1. Piffin | Mar 27, 2005 05:26pm | #1
    You are better off with solid lumber( not truss) framing and steel roof. Skin the cieling inside with type X 5/8" guyprock and tape the seams.
  2. DANL | Mar 27, 2005 06:15pm | #2
    Would you need sheathing? I thought there were clips or something you could use to attach metal roofing, or at least that corrugated decking material, to the steel trusses. You could make a sort of sandwich with drywall, then plywood, then either metal or cementitious shingles.
  3. BrianWI | Mar 27, 2005 06:43pm | #3
    piffin is right. but if your hell bent on steel know that structural steel should be protected from the heat. just because its not combustible doesnt always make it a good fire barrier.  there is a spray foam type product ive seen installed on structural steel to keep the heat off of it.
    if you did have steel exposed to fire and it witheld, the inspector would test it for hardness. if it hardens or weakens you would have to replace it anyway.
  4. MikeR | Mar 27, 2005 07:08pm | #4
    Thanks guys.  Keep in mind however I did say 6 feet by 6 feet so the aspect of protecting the steel is not really an issue as its just an out building.  My main goal is just to prevent and accidential fires on the generator from igniting the roof framing...hence my intention of using steel as opposed to any wood.
    I had considered the 5/8" Type X like Piffin said and just wrapping the whole roof understructure in it.  Then I could use solid lumber framing and regular plywood sheathing.  I just thought this would be more work than say something which is not flammable...like say steel sheathing on a battleship ;)
    Mike
    1. Piffin | Mar 27, 2005 07:19pm | #5
      If you had a fire in a gen shed, it would be a liquid fuels fire, even if it started as an electrical fire. That means flame would fine a way to vent and torch out through seams in and at edges of a steel roof, so you would still need to protect it with type X or a spray on seal coat anyway to stop the flame spread and air flow as well as to protect the steel itself.Since your goal is to protect adjacent buildings from spread, I stand with first recommendation.
      1. MikeR | Mar 27, 2005 10:16pm | #7
        Piffin,
        Got ya.  Following along that line...Do you then think it might be wise to install a ceiling of Type X (maybe even two layers to make a 90 minute barrier) on metal furring channel as a barrier to the roof structure as that would be even easier to build than wrapping all the undersides of the framing members?
        That would actually be very easy to do and yet still have a normal frame roof structure, sheathing, etc.
        Mike
  5. UncleDunc | Mar 27, 2005 09:38pm | #6
    Concrete, cast in place.
    1. MikeR | Mar 27, 2005 10:18pm | #8
      Hmmm?  Didn't think of that.  A 6' x 6' slab however might require some engineering to make the span?  I'm thinking it would have to be about 6" thick?  I'm not a P.E. however so thats just my guess?
      1. jimstock1 | Mar 27, 2005 10:26pm | #9
        Mike-
        What about another concrete idea?
        Look at precast concrete planks, span would be no problem and they may even help you size the plank for that span. Check out these companies: Spancrete of Fabcon.
      2. UncleDunc | Mar 27, 2005 11:05pm | #10
        I also am not an engineer, so please don't consider this as engineering advice. :) If I were building one for myself, I would feel pretty confident about a 4" slab with a #3 rebar around the perimeter about 1-1/2" or 2" in from the edge and a grid of #3 rebar on 6" centers.
      3. Piffin | Mar 28, 2005 12:01am | #11
        it is not the thickness, it's the steel.Wrap frame members? just screw the rock to the bottom edges
Exterior Materials for a Midcentury Home
Travis talks with the architect about his thought process for choosing the materials that create a functional and seamless aesthetic for this house.
  • Superstable Sawhorse
  • Convert a Porch to a Mudroom
  • Podcast 599: Trees Moving Buildings, Epic Thermal Bypasses, and Supplemental Dehumidification
  • Podcast 599: Members-only Aftershow — Tools That Changed Residential Construction
BOOKS, DVDs, & MERCH
Shop the Store
  • Code Check Complete 3rd Edition
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
