FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Flashing DWV on granular asphalt flat roof
rdy4trvl | Posted in General Discussion on December 5, 2021 06:19pm
I’m running a 2″ DWV pipe up through an almost flat roof (~1/12).  The roof is granular asphalt (10 yrs, will be replaced in next year +/-).  Because the DWV is within 10 feet of an operatable skylight, the pipe will extend 36″ above the roof.
What is an appropriate, cost-effective (will be removed in next year) means to flash the pipe?
Possibly Oatey 2″ Galvanized flashing https://tinyurl.com/y6o4gpfx  with caulking on the underside near edges, nailed near edge into place and acrylic flashing and mesh on top of the edges?
  1. florida | Dec 06, 2021 03:46pm | #1
    Yes, the Oatley flashing will be fine. I'd run a bunch of poly under it, nail it down good then seal all the edges with poly.
    1. rdy4trvl | Dec 06, 2021 04:08pm | #2
      The poly - is that some type of flashing tape or simple plastic?
      Thanks Florida!
Replace Rotten Boards in a Roof Overhang
Readers and an expert consider the source of the problem and how to fix it without completely reroofing.
  • Convert a Porch to a Mudroom
  • Podcast 599: Trees Moving Buildings, Epic Thermal Bypasses, and Supplemental Dehumidification
  • Podcast 599: Members-only Aftershow — Tools That Changed Residential Construction
  • Remodeling Done Right
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
