flashing my windows…………..
Craigabooey | Posted in Construction Techniques on August 16, 2006 06:37am
I’m about ready to put all my windows in my new dormer and needed some advice on flashing the window openings. I haven’t yet  housewrapped the house. Do I have too before I put the windows in? I’ve seen lots of builders flash the openings with tar paper then put the windows in and house wrap later. This is what I  would like to do. Any problems with this method? Or any better alternatives?
        Craig
  1. Shep | Aug 16, 2006 07:31pm | #1
    Use Vycor. Its a self adhesive rubber flashing.
    flash the RO sill, wrapping the Vycor over the paper on the outside.
    Run strips of Vycor up along the sides of the RO on the sheathing.
    Install a final strip of Vycor over the head flashing.
  2. JohnSprung | Aug 18, 2006 02:52am | #2
    You need to leave the bottom of the sill flashing loose so you can get the housewrap under it.  The wrap goes over the rest of the flashing.  Think thru the path that a drop of water would take, you want to shed it to the outside, not funnel it in.
    -- J.S.
  3. davidmeiland | Aug 18, 2006 03:42am | #3
    Here's the Tyvek method... highly recommended (this same method is increasingly shown on window manufacturers sites and is also on the Typar site). You need to splurge on a roll of Flexwrap to make sill pans, or actually buy/make a galv or copper sill pan. IMO any window install without a sill pan is asking for trouble. I figure the cost of Flexwrap and Vycor for an average window install at about $20.
    http://www2.dupont.com/Tyvek_Construction/en_US/assets/downloads/K02107HRBeforeInstall.pdf#search=%22Tyvek%20window%20flashing%20details%22
    The same detail can be done with felt as well, which is what I like to use rather than wrap.
  4. MikeCallahan | Aug 18, 2006 06:50am | #4
    On the west coast our houses are already covered with a shell of shear ply before the windows are installed. Heres how we do it most of the time. I uses 6" strips cut out of a roll of bituthane instead of vycor. It is better and cheaper. Tar paper up to the window sill Flash the sill over the plywood and fold an inch or two inside the sill surface. Now install the window. No need to caulk under the fin if you use bituthane but you can if you want. Apply the side pieces over the fin and then install the tar paper and siding. Before the siding goes over the top and after the tarpaper is applied, flash over the head. The tar paper should be cut so that it just overlaps the fin but does not fit tight to the window. This gives the bituthane something to stick to when you flash the head. I always use 30# tarpaper because I think housewrap is bogus.
    Mike Callahan, Lake Tahoe, Ca.
Achieve a Flat Drywall Finish
These products and methods result in the clean lines essential to a midcentury-modern aesthetic.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
