Flat Roof W/ Deck
emana | Posted in Construction Techniques on November 27, 2006 06:32am
We are in the midst of my renovation and there is a 5’6″ wide section of flat roof above the 1st floor of my house that will act sort of like a patio for the rooms adjacent to it (The house bumped out down below but stopped at the 1st story).
The framers mentioned a product called Dibiden (sp?) that is applied w/ heat to make this roof area water tight and also give the ability to walk on it afterward soft of like a floor.
The siding guy mentioned another product but didn’t know too much about it that wasn’t applied w/ heat.
Anyone here have any experience w/ this kind of stuff? Any recommendations? This section of roof happens to be above the new shop so I cannot stress the importance of this roof being right…=)
Thanks!
Ed
  1. JoeArchitect | Nov 27, 2006 09:26am | #1
    You may get a few different options suggested here. Some will say to use a membrane roof and just walk on that. Some will say use a membrane roof under a wood deck surface.  I think though, your membrane roof warranty becomes void when you start using it as a patio by placing furniture or a deck on it. The deck would have to be above and not in contact with the membrane.
    The product I like to spec for these type of situations is Dex-O-Tex, manufactured by Crossfields Products Corp. It's an trowel applied elastomeric surface. It comes in colors, is non-slip, and expands and contracts with temperture fluctuations. It can be appied over plywood, concrete, etc.
  2. Piffin | Nov 28, 2006 09:04am | #2
    The dibuten is a modified bitumen torch down single ply roof product. It is quiet tough.
    But it is ver ugly on a roof deck.
    It is also dangerous to apply and difficult to work to a wall flshing and have adecent looking job. I do not think of it as appropriate for residential use.
    I prefer an EPDM rubber roof membrane,which is glued down with contact cement and associated flashings. If you want to use the advanced search feature here, using keywords EPDM and IPE`, you will see several photos and threads on decks done in similar situations.
