i have a customer that wants a tv installed above a working wood burning fireplace. i have seen it done in photos but was wondering about the heat and smoke damage to tv.
If the fireplace is working properly, you shouldn't have to worry about heat and/or smoke damage to the wall (or a TV) above it. Does the wall currently show signs of such? If so, somebody should check out the fireplace.
That said, above fireplaces is generally not a good place for TVs since it places them too high to be viewed comfortably for more than a few minutes. This has been discussed here before, so you may wanna do a search and check it out.
Mike Hennessy
Pittsburgh, PA
PS: Guitar player?
thank you and everyone else for the info. i got down in front of my lcd tv and the picture faded out and yes i am a guitar player i just cant play much anymore. hands hurt. thanks again to all
"i am a guitar player i just cant play much anymore. hands hurt."
Time to switch to bottleneck blues w/ a flatpick. ;-)
Mike HennessyPittsburgh, PA
If the fireplace works right, smoke should be no concern.
these flat screens do make a lot of heat tho, on their own and require decent ventilation around them.
There have been other threads on the subject here. I suggest you try thed advanced search using keywords TV + fireplace
I've done a few and they've been fine. I like to recess them into the wall, leaving plenty of ventilation space around the tv, and mount the tv on an arm that lets you tip it down for a better viewing angle.
mine is above the fireplace,it does pick up some heat but doesn't seem to be alot.BUT.... i would never do it again ,with it up that high it picks up reflections from windows and even lights that are hanging from the ceiling.mine is not a plasma with a glass front[i can't imagine how bad it would be] but a lcd with a matte finish screen. looked good on paper,but to tell you how bad it is ,i go downstairs and watch the old tube tv and enjoy it much more.larry
if a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
I had a 40" LCD over my fireplace insert and removed it. The insert puts out so much heat, I was afraid the TV gets damaged. As far as I know, heat damages electronics.
On the pic you can still see the mounting holes in the brick from the TV wall mount.
Martin
