I have a two story garage (detached) with a heated first floor. The first floor ceiling is insulated with fiberglass batting without a vapor barrier. The second floor is unheated and used for storage/exercise area. The second floor ceiling and walls are insulated, sheetrocked, and the roof is shake.
I want to install flooring over the plywood subfloor and I an concerned about the possibility of laminate flooring (or any material) acting as a vapor barrier, trapping moisture and rotting the flooring or the subfloor.
Any comments or suggestions are appreciated
Greetings j, as a new poster Welcome to Breaktime.
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
Cheers
thanks
jl
