I have a laminate hard wood floor in the living room and some boards have become unglued and “pop” when they are stepped on. I’ve been told that if I drill a small hole in the offending board and sqeeze an epoxy glue under the board that this will solve the problem. Sounds simple enough. Is that all there is to it? I would appreciate your comments/recommendations.
This is a standard repair for loose parquet blocks -- except polyester resin rather than epoxy because it flows better -- but you will probably find that, having glued down one board, the board next to it comes loose.
IanDG
Thanks Ian, I'll remember the polyester resin. Ken
