ICF Rough framing cost vs. conventional. ICF firm installs ICF and my crew frames out joists, interiors, & roof. I am looking for approximate $/ft difference between conventional framing vs. ICF. This house comes in at about $7.15/ft conventional.
The recipe for linoleum hasn't changed much in nearly 170 years, yet it's still one of the greenest floors money can buy.
Greetings A,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
half of good living is staying out of bad situations
I can't answer the question but the guys at http://www.ICFWEB.com will be able to.
If you note similar past threads, you will notice that framing costs varies across the country from $2.50 to $16/ft
So there is little consistancy - the variation for non-conventional hybrid work like this will probably have an even wider swing.
You are expecting the frame to be less I'll bet, but probably it won't be too much less, depending what is included. For instance,
What is the ext siding? maybe you need to add strapping for that detail first - maybe need strapping inside too. Now you have spent almost as much as framing a conventional wall.
Then get to attaching trusses. Fitting that plate can get hairy...
