the hole is dug. pretty wet, tiny bubbles of water rising in a few spots.building a two story gable using a 6” icf block on a 6” bed of stone, i’m thinking of 2x10s 24” apart for the footing. does this seem adequate or overkill? thanks
There's a constant source of clean water for you to use, and all you have to do is collect it.
The ground is weet what? Sand, clay, gravel???
Footing size is a factor of load and carrying capacity of the soil.
Most times 20-24" wide is fine, but I have done them 30" wide in wet clay
according to a test pit dug nearby by the septic designer,the soil is "olive,silt loam,firm in place,friable to crush,mottled,water seep @ 62""
that dosent mean nothing, septic people got their own way of classifing. is it sand, sand clay, clay gravel
looks like sandy clay
can you contact a soils engineer who can state the approx bearing capacity of that?
How high will your ICF walls be? Stem wall or 1st and/or 2nd story wall?
only the foundation wall,7'9"
