Rather than try to insulate and heat the large barn, I’ve decided to expand the attached shed (see pic). This will be used to restore/repair cars and I’d like it to be VERY energy efficient.
Both the shed and the barn have concrete floors but as far as I can tell, neither have any kind of foundation below the slabs. The shed (about 8 x 15′) concrete is cracked near the back/center but is not currently heaved around that crack. The shed needs to be widened about 3-4 feet and lengthened about the same, so I’ll need to pour more concrete. What I’d like advice about is whether to consider a FPSF for the new pour, or would I be better off digging down to the frost line (30″)? If the major portion of this floor is in essence, ‘floating’, will attaching concrete with footings cause problems? Also, as I understand it, I’ll need to drill horizontal holes in the old slab, for rebar, which will extend into the new concrete. How far apart can/should these be?
Any thoughts/suggestions greatly appreciated.
Thanks.
Thon
