Who makes circular saws that can cut more than 45 degrees? Where do you get them?
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
Im not sure exactly which saw. I think maybe milwaukie. But tool crib of the north through amazon has about every major brand of saw. Check them out
Darkworksite4:
El americano pasado hacia fuera ase la bandera
Bosch has a new one that will lay over to about 56°
goodwood:
I believe that the Milwaukee circular saw tilts 50 degrees. I have this saw and it is the best circular saw that I have ever owned. It also received the highest rating in the Fine Homebuilding magazine. You can find it at Home Depot for $139.00.
Stan
Skill makes an 8-1/4 that cuts upto 60 degrees
good luck
If you already have a decent framing saw, just cut yourself a wedge at a known angle and then adjust your saw accordingly.
Norse
