Frost protected slab
inperfectionist | Posted in Construction Techniques on September 27, 2008 04:08am
Happy Friday,
I’m starting a frame on frost protected slab type foundation monday. The plans are slim on details. I’m looking for suggestions on the detail where the wall/siding meets the vertcal foam insulation at the slab perimeter.
At this point, although the owners are not 100% sure, the siding likely will be either vinyl, or fiber cement claps. Walls are 2×6 w 1/2″ ply sheathing.
In my (limited) experiences looking at existing work w either ICFs or foam insulation on the foundation, I have yet to see a really slick job on this detail.
Sure would like to build something that doesn’t look like s&%$.
Many thanks, Harry
  1. SWASAN | Sep 27, 2008 04:35am | #1
    I built my house with a frost protected slab 8 years ago. The exterior stud walls
    were kept in line with the concrete edge(allowing normal anchor bolts to be used)
    and 7/16" sheathing was applied. I then made flashing out of white coil stock that
    started 6" up the wall and was bent out and down over the 2" rigid XPS. I continued
    the flashing down the foam to a below grade level and bent the bottom edge over
    on itself and had it kick out at an angle to give some support/strength to the 8'
    pieces of flashing. House wrap was brought down over the flashing and taped. I
    then added 1" of XPS and strapped over it to create a rain screen wall. I did this
    just a little off of level for board and batten wood siding. This method allowed the
    boards to extended down over the flashing/XPS with about 1/4" between the back
    of the boards and the metal. This looks very neat and clean when done. Good Luck!
  2. IdahoDon | Sep 27, 2008 10:38pm | #2
    Synthetic stucco over the foam seems to be what most people use.  The walls should extend out far enough that the foam isn't sticking out like a sore thumb.
    1. inperfectionist | Sep 28, 2008 02:22pm | #3
      Thanks for the ideas.Looks like one of the main considerations is to somehow get the siding out so the insulation doesn't look like a big bump.Harry
  3. Marson | Sep 28, 2008 04:43pm | #4
    We hang our plates 2". I have yet to see a house with the protruding foam on the foundation that didn't look like h***.
