Here is the problem encountered.
Master shower and separate master tub are cantilevered out over walkout wall of basement. Supply line run out into this cantilever (boxed in and insulated w/ fiberglass). These fixtures have not been in use. The supply lines extend approx 12 in beyond basement wall, then stub up through floor and into interior partition walls. Tried to use shower last night, had cold water, but when turned all the way to hot (single handle control), just a trickle of cold water. Tried the tub, no cold but some plenty of hot. Placed space heaters under the area in the basement within 18 inches or so of pipe, has been there approx 15 hours, no improvement. Temp outside has been above freezing for 24 hours. I would have thought that the small amount of water passing through for 15 hours would have cleared the line by now, or no? I am at a loss.
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
Just to add, we are in mid missouri, and this week several nights in single digits with extreme wind chill. I think I can prevent in future, but how to get unfrozen. The walls are ceramic tile and I am now wondering if the freeze started in the soffit and then went into the wall above where I can't get heat to it without tearing out tile. I have removet the plate for the single handle controller allowing a few inches around the nozzle, but can't really get any heat into the area.
if you finally get it thawed....
the fix is to make sure the insulation ( probably rigid foam is best in this case ) is ONLY on the cold side, so the heat from the warm side can keep the pipes above freezing
i had this problem with customers who slept with the heat off and the windows open
they never told me about their sleeping arrangements until the bathroom froze up
i finally convinced them to leave the thermostat alone in the bathMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
Aim a hairdryer into the gap around the faucet.
You have junk in the line, not ice.
Try disassembly of fixtures to locate obstruction.
Problem solved, now that I feel like an idiot. Pulled the cartridge, not fun. Dont know how, but the majority of the black rubber side off of the cartridge was sucked down the slot feeding water into the valve. Just enough to grab with needle nose and pull out. New cartridges ($40 each, or should I say ouch) and we have water. Thanks to all.
got a welder? if the pipes are copper you can just zap them...they rent what are called "thaw boxes" all over the place up here in alaska...but in essence its just a glorified welder..They use that method the most frequent up here
All I ever wanted in life was an unfair advantage...
A few months ago I had similar symptoms and wound up with no flow through a single handle faucet. The temperature was well above freezing.
I back flushed by first turning off the water supply and opening a "bleed" faucet that was closer to the water source than the blocked one. I then back flushed through the blocked faucet with compressed air which forced water, crud, and air through the bleed faucet. It took about six cycles of back-flushing and then running water before the blockage was cleared.
This doesn't take very long to try, and then you would know.
If you get a "trickle" of water then running the water for 10 minutes or so should melt any ice in the line. If that doesn't do it then it's probably not a frozen pipe.
if it IS a frozen pipe (or you still strongly suspect it) then be sure to examine the area around and below the pipes thoroughly several times over several days for any sign of a leak -- letting a slow leak go for a week could result in some very expensive repairs.
And "yes" to what someone else said about having the insulation on the OUTSIDE of the pipe area only -- don't surround the pipe with insulation on both sides, but only put it between the pipe and the outside wall. Usually the best insulation to use in this case is foam sheet insulation, since you can get a lot of insulation value into 1-2 inches of space between pipe and outside wall.
