Cheapskate landlord here would like to make some furnace filters.
I have several air handlers that require an odd size filter. The cut to size filter material needs an edge to be able to slide it into the slot. I have some in Carrier systems that have a thin gauge aluminum channel around the perimeter. Anyone know where to get material something like this or have other ideas? Thanks as always.
MSC Sells different types of filter material and pre made metal "pad holding" frames that hold the filter material. You can find them at http://www.mscdirect.com Check page 4149 in their catalog for the frames, the filter material rolls are on that, and the surrounding pages.
It may work for you if they are available in the size you need.
