I’m a new home owner in the Boston area and ice damming is destroying my ceiling and Frenchwwod sliders in a sunroom. Someone recommended that I look into galvanized aluminum roofing (standing seam roof panels)and water and ice shield as a solution. Does anyone have any advice/experience with it? This has been a recurring problem because the roof is at the back of the house which gets little sunshine and the roof pitch fosters the buildup of snow. Thank you.
An FHB Podcast listener wonders if they can fix a failing foundation with PWF, the crew weighs in.
I have been up that way a few times and have noticed a lot of metal roofing on the bottoms for this very reason. Down here in PA and NJ we use Ice/Water shield under the shingles on the bottom 6' of the roof and all valley's and walls. Some people use Ice Cables{Wires that run in a zig zag manner along the bottoms they heat up when activated} with great success if you can live with the look.
I'm a new home owner in the Boston area and ice damming is destroying my ceiling and Frenchwwod sliders in a sunroom. Someone recommended that I look into galvanized aluminum roofing (standing seam roof panels)and water and ice shield as a solution. Does anyone have any advice/experience with it? This has been a recurring problem because the roof is at the back of the house which gets little sunshine and the roof pitch fosters the buildup of snow. Thank you.
