I am replacing my shallow well pump, and the new pump I have needs a 1″ T fitting to make it work. I found a galvanized piece at HD that will work, is it safe to use galvanized or should I head to a plumbing store and get copper or brass?
There's a constant source of clean water for you to use, and all you have to do is collect it.
I am replacing my shallow well pump, and the new pump I have needs a 1" T fitting to make it work. I found a galvanized piece at HD that will work, is it safe to use galvanized or should I head to a plumbing store and get copper or brass?
