I’m within 2 weeks of decking and Owen/corning 30yr. Arch. shingles. The roof begins with a 10’x36′ front porch that blends into the Gambrel roof. It’s a Dutch Design with two Dormers.
How would you deal with the transition between the upper steep roof and the long lower angled roof as I shingle? It’s a Dutch design.
Thanks,
Bill
here's one example...
this shows the 2x4 sub-fascia
and what it looks like when it's done
Edited 1/3/2008 11:08 pm ET by MikeSmith
Edited 1/3/2008 11:09 pm ET by MikeSmith
Edited 1/3/2008 11:10 pm ET by MikeSmith
The 2x4 width looks clean and solid. Considering the picture I posted and the one below, how would you make that kind of trim work?
The roof framing is 16" on center, with the dormers being 44" wide, and each has a 2x4 that is glued, ring-shank nailed and 3-1/2" screwed to each roof joist/rafter for added strength.
Thanks for the help,
Bill
Edited 1/3/2008 11:35 pm ET by BilljustBill
I heated and bent my shingles when I made the turn. I didn't know if it would work.
It did.
As I read your Q you are asking not about that upper break, but where a lower pitcch porch roof ties in.
I do that with a flashing bent to the right pitcch. shingle up to the break, run a vycor along sealed to top of shing a couple inches, then place the flashing nailed at top only, then start shingling up all over again.
At that top break, I have heated the shingles to bend over, but generally I set anther eave edge metal and starter again there too, but not a full facial wrtap like Mike.
bill, we're talking about the upper break , right ?
another faux solution is to shingle up to the break and nail a primed and painted 1x4 right onto the top shingle of the lower steep pitch
that becomes your "fascia" for the upper roof.... run you drip edge over it.. and start shingling your upper roof
bending a shingle over the break is the intuitive way to do it... it works.. but it looks like shid ..
c'mon youse guys... lessee some pics of gambrel roof break details Mike Smith Rhode Island : Design / Build / Repair / Restore
here's two more.. this is pretty typical also..
and the other side
Edited 1/4/2008 6:43 am ET by MikeSmith
Edited 1/4/2008 6:44 am ET by MikeSmith
I don't think I've done one in the digital age so I can't find any pics. My methods have been to do the 1X and drip edge at the top of the steep pitch or preferably install a piece of flashing showing about 5" on the low side and extending about the same on the upper roof under the shingles.
All I've ever done is reroofs on this type structure and if there ever was a full cornice between the two pitches, it was long gone before I got there. Usually the last roofer bent the shingles thru the pitch change.http://grantlogan.net/
My mother once said to me, "Elwood" -- she always called me Elwood -- "Elwood, in this world you must be oh so smart or oh so pleasant." For years I tried smart. I recommend pleasant.
Elwood P. Dowde (James Stewart), "Harvey"
