All-
My old compressor finally gave up the ghost (YAY). I’ve got my eye on a 2 stage, 7.5hp, upright. I want to install it in an unheated garage. (will be exposed to freezing temps) What’s anybodies thoughts on this. I can put it back in the basement if the garage is a bad idea. Thanks
England1
Water will freeze in the bottom of the tank but if you drain it regularly it shouldn't be a problem.
Just remember to drain it regularly..
the other issue is wear.. cold starts of compressors will quickly wear out the compressor part because oil drains off and it's only splash lubed..
Change compressor oil on a regular basis (every 20 operating hours) untill you have about 100 hours of running time on the compressor then switch to a synthetic oil.. change that as well about every 50 hours or so as long as the compressor cycles from cold to hot.
Sounds like the basement will be the best place ... thanks
