I know you’re supposed to install a gasket at the bottom of a garage door, but I’m wondering what about the sides? If you don’t have a gasket there, then don’t you get drafts coming in through the sides of the door? If you do put a gasket up both sides, and across the top (why not?), then unlike the bottom of the garage door where the gasket is nailed to the bottom of the door, I imagine you would nail the gasket to the interior edge of the jamb. Would I go to a garage door company for this product?
there is a "board" with a rubber type wipe on it for weather stripping your OHD...
it goes on the inside of the outside portion of the jamb and the wipe just touches the outside od the door..
they can be had at the Big Boxes...
WOW!!! What a Ride!
