My wish has almost been granted. My 1 car garage has been demo’d and I’m building a 2 car garage with an accessory slab room. I’m going to install a hydronic radiant heat system in both slabs. I’ve come to understand(?) that due to compression and live loads not just any insulation board should be placed under a radiant slab. DOW makes a product called HIGH LOAD for this purpose. It comes it varies compressive strengths.
Has anyone used this product and which type should I use for a 2 car garage and a 12X12 room ?
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
Check the website of the foam board manufacterers. They list compressive strengths. You'll find that nearly anything they offer will be sufficient.
You'll need to know that concrete has a density of about 150 pounds per cubic foot. From that and your vehicle you can calculate everything you need.
I use 25 PSI foam FoamulR250 the pink stuff or dow 25psi
R-control beadboard is treated with borates so the bugs won't eat it the first month it's there.
http://www.r-control.com/ They sell direct from plants around the country, but you may not need that much. Last I got was minimum of $1600 couple years ago for free delivery. That's a lot of sheets.
It's the cheapest stuff, used to be about half of what blueboard cost.
Works great, you don't need that super density stuff.
Joe H
