The range I am installing says to use a ‘commercial’ flex line. Is that a different size/material/code spec what? I found a flex line in stainless made by Dormont and the rest are hardward store types with coating over the flex. What is best for behind a range?
Those who can make you believe in absurdities can make you commit atrocities- Voltaire
You know that ugly yellow pipe going up the outside of your chimney?
That's what we used for flex's on the gas cook tops in that condo project.
Reson , they were passing through a cabinet wall, & the inspector said we could not use an appliance flex.
The commercial flex's I have, have an integrated "kill" valve incase of a fire, or an earthquake,
The coated SS you get in the box stores work just fine.
Just make sure it meet sthe BTU requirement.
If your range has a 3/8" connection then the 1/2"male by 3/8" female styl flex is fine, but if you have a 1/2" connection then I would use the 3/4" x 1/2" appliance connector.
“How many observe Christ’s birthday! How few, his precepts! O! ‘tis easier to keep Holidays than Commandments.” —Benjamin Franklin
Just had to remind me of that pipe didn't you? Oh man......
Wolf specifies a 1/2 ID hose is all they say. Those who can make you believe in absurdities can make you commit atrocities- Voltaire
1/2" ID flex is usually going to have a fitting on the end that looks similar to that tub fitting you have.
3/4" male threads with 1/2" female threads on the inside.“How many observe Christ’s birthday! How few, his precepts! O! ‘tis easier to keep Holidays than Commandments.” —Benjamin Franklin
