When connecting a flex hose to a stove does the adapter have to be a pipe thread on each side? (No flare on male end to the flex hose.)
Learn how to fight wood-boring beetles and prevent home infestations with expert advice from Richard D. Kramer, an authority in pest control.
Greetings M,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
Cheers
'Nemo me impune lacesset'
greetings rez...
This post, in response to his question will elicit a "HUH" from here....
you give it a try...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
The answer is yes. One end has a (female) pipe thread the other is (male) flared for connecting to the flex pipe. You should not screw the flared end into the female pipe thread.
