cusotmers have a set of built in storage caeses iwth Tv center
has white melamine doors and drawer fronts. those I can swap out, and will
but how about the other parts of the melamine thta will still show.
She wants maple now, I was just going to glue a veneer over it
but was curious how the glues will hold to the slick shiny melamine
and the best glue to use in this situation
any ideas
thanks
I've used solvent base contact cement successfully, after roughing up the surface. A little depends on your veneer backing, if any.
If you need to bond melamine to melamine, Roo glue is supposed to do a good job. Not sure about veneering with it, but you can check them out here: http://www.rooglue.com/
